Bulk item adjust in a scene
Hi,
I have several scenes with 30 to 40 devices in them and I was wondering if there was a way to set levels and ramp rates for multiple devices at once?   It's lot of extra work to go through and set each one individually for that scene.
2 hours ago, anthon710 said:
Hi,
No since there's no way for the isy to know what you want things to be. If you have the pro version, you could turn off write updates which will make the process a little faster since the write will not happen at that moment.
You could also add all responders first (and configure) then the controllers. The scene attributes for each device will automatically be copied to the controller vs needing to write each on 1 at a time
Hopefully we will get the ability to bulk adjust everything down to 90% someday.... or export the current settings and import them back in on an excel sheet.
Edited by anthon710
