Detecting Daylight Savings Time occurrence with a Variable
@hart2hart If there is a reboot command that you can send via REST, then you could put that directly into the program I wrote above using a network resource.  But I don't know that Nodelink does that via a REST command.  If indeed there is a REST command for ISY reboot, it would be good to have it added to the REST wiki.
You send reboot ISY relay command to nodelink . I don’t know what it actually sends to ISY. I assumed it was a REST command but not sure. I’ll edit prior post.
