Cannot set parameter in fibaro 222
Attempting to set parameter 20 to a value of 3.  I get the error
1- z-wave command failed [ZWave 29 set config ZW004_005 20/1/3]
2- z-wave  command failed [ZWave Query Config ZW004_005 param 20]
If I do a Query on ZW004_005 it appears to work.
any help please.
The query works or the the value is changed and the query has confirmed it?
Have you looked to see if the requirement is for a 1 or 2 byte value?
yes, it has a parameter 20  requiring 1 byte  in the range of 1-3
I realized my mistake.  I was trying to write to one of the sub nodes rather than the parent node
of the FBS-222.
of the FBS-222.
Been there, done that... ?
