HBrondum01 Posted November 8, 2020 Posted November 8, 2020 Attempting to set parameter 20 to a value of 3. I get the error 1- z-wave command failed [ZWave 29 set config ZW004_005 20/1/3] 2- z-wave command failed [ZWave Query Config ZW004_005 param 20] If I do a Query on ZW004_005 it appears to work. any help please.
Mecheng70 Posted November 8, 2020 Posted November 8, 2020 The query works or the the value is changed and the query has confirmed it? Have you looked to see if the requirement is for a 1 or 2 byte value?
Mecheng70 Posted November 8, 2020 Posted November 8, 2020 Are you sure it has a parameter 20? "Double Relay Switch | FIBARO Manuals" https://manuals.fibaro.com/double-relay-switch/
HBrondum01 Posted November 8, 2020 Author Posted November 8, 2020 On 11/8/2020 at 7:14 AM, Mecheng70 said: The query works or the the value is changed and the query has confirmed it? Have you looked to see if the requirement is for a 1 or 2 byte value? Expand yes, it has a parameter 20 requiring 1 byte in the range of 1-3
HBrondum01 Posted November 9, 2020 Author Posted November 9, 2020 On 11/8/2020 at 10:25 PM, HBrondum01 said: yes, it has a parameter 20 requiring 1 byte in the range of 1-3 Expand I realized my mistake. I was trying to write to one of the sub nodes rather than the parent node of the FBS-222.
Mecheng70 Posted November 15, 2020 Posted November 15, 2020 On 11/9/2020 at 12:58 AM, HBrondum01 said: I realized my mistake. I was trying to write to one of the sub nodes rather than the parent node of the FBS-222. Expand Been there, done that... ?
