Cannot locate a device that shows up in my "imported" list of devices
  On 11/21/2020 at 11:50 PM, RFiddletown said:
Cannot locate a device that shows up in my "imported" list of devices, can the device be made to beep/buzz using a ISY command so I can track it down?
Expand
Sounds like you added the device by choose add existing links. It may not be there.
Could be an old link from something else that's always been present. 1 of the many reasons everyone recommends factory resetting your devices when switching systems. What does the Isy say the device is?
What did you use prior to the Isy? It may be the Id of whatever hub you used prior
  • Thanks 1
If you did not Factory Reset the module first.
We have seen some modules having test addresses in them from the factory.
So if you used add existing links. I would also think it maybe a link for a module not in your setup.
  • Thanks 1
Expand
Thank you for your help. The missing device is: 2472D Dual Band Outlet Link Dimmer v.41. So I assume it's located in the wall somewhere or is a "phantom". I'm migrating from a Hub and factory resetting all my devices would be extremely difficult. I think I'll just remove it from the devices list and see what happens.
Thanks again...
Expand
Thanks again...
You could try to control it from the ISY admin console and see if it responds with expected status or gives an error trying to communicate.
Also, if you wrote down the 6 digit Insteon ID before deleting, you could try to re-link it by using "New INSTEON device" and inserting the ID again.
(If those show the device exists, yes there is a way to get it to beep, or turn the light on/off repeatedly while trying to locate)
Edited by gzahar
  • Thanks 1
Thanks again...
Expand
When it comes to the Isy, most times, the easy way turns out to be the hard way long term.
Edited by lilyoyo1
  • Thanks 1
Expand
Thanks for the suggestion, I'll give it a try. When I "control" it from the ISY it responds as expected (Status is: On/Off) and a linked outlet turns on/off as expected. Looks like I'll have to get it to beep and send my wife around to find it! LOL
They are not very loud (don't have the dimmer outlet, but I have a dual outlet).
A program like this should work (remember to stop it if after you locate the device).  Right click the program and "Run Then" to start.
Outlet Beep - [ID 0144][Parent 0005]
        Repeat Every  3 seconds
           Set 'Missing Outlet' Beep
  • Thanks 1
