ISY-994 power supply question regarding voltage
robin71
Hi,
Last night the power supply on my ISY went out and I don't have another 5V adapter. I thought I remember reading on the forums that the voltage could be a range higher than 5V.
I found a center positive 12V adapter from an old router and it is working, however, can there be any long-term damage to the ISY running at this voltage?
Lastly, are the dimensions of the connector 2.5mm X 5.5mm?
Thanks in advance!
On 12/14/2020 at 6:21 PM, Brian H said:
The replacement supply in the UDI store is 12Volt 1 Amp. So that will be fine.
Thanks! Those are the exact specs of the power adapter I was saving from an old Netgear router. I'm glad I did!
The ISY994, and the ISY99 before it, have always been rock-solid devices from my experiences. Besides a power supply, PLM, or maybe an SD card, has anyone had one go bad? I wish I could say the same about INSTEON Switchlincs.
Edited by robin71
