How to get rid of Security Warning alert?
I've got my ISY setup on my home LAN, which doesn't have external access enabled (except via a VPN that I use when I travel).  Every time i launch the Admin Console I get this Security Warning alert.  Neither button seems to do anything meaningful, other than dismiss the alert.  How can I get this alert to stop showing up?  I'm happy to install a LetsEncrypt certificate if needed, or something like that.
1917293179_ScreenShot2020-12-29at8_55_14AM.thumb.png.822e2e8a7c2c8791c7c19e39dbcc6f53.png
Well, I don't know why I didn't see this before, but I just found this old thread:
In there, Michael mentioned simply using a self-signed cert, with a link to the details in  http://www.universal-devices.com/docs/I ... 0Guide.pdf. I just did that and that seems to have done the trick.  Just took a couple clicks using the dashboard and not the admin console, which was where I had been looking.
I have found better performance offloading the SSL encryption to Stunnel on a PC.  If you find slow connections to the ISY using HTTPS, consider this option.
