Insteon Thermostat Turning Off Randomly When On Heat Mode
I'm running ISY version 4.8
Several times per week (sometimes per day), my Insteon thermostats turn off when they are set to heat mode.  To be specific, the mode turns to off and the heat setpoint resets to 60 degrees.  I do not have an ISY program (or anything) that would cause this to happen.
To get around the issue, I have a program to capture this event and automatically change the mode back to heat and a heat set point to 67... but it's driving me crazy.
Thoughts?
Also, is there a way to capture a heat setpoint temp change (e.g. as an ISY variable), then use that variable as the thermostat's heat setpoint?
