Z-Wave Switch Recommendations
For those of you using Z-Wave in earnest with your ISY setup, are there any Z-Wave switches that support the N-Way switching feature that Insteon switches have? Are there any good alternatives to Insteon Keypadlincs? I really like the layout and arrangement of the Keypadlinc buttons. Better than Lutron.
The direct linking to create the N-Way (3-way typical) setups?  Nope.
Not until you move up into higher end systems of which you've said you don't like the Lutron "style" but most other keypads out there mimick that button style of rows.  The keypads aka "Scene Controllers" available with Z-Wave are mostly all OLD non Plus Z-Wave.
When it comes to lighting, temper your expectations when it comes to zwave. While some do have a few novel (some gimmicky) features, none comes close to being as flexible and configurable as insteon for actual use. It's extremely limiting when it comes to cross linking as well as different lighting triggers the way insteon is.
