Insteon leak sensor for pure water?
jzh
Hi
i'm using a lot of insteon leak sensors, they work great. But it can't detect filtered pure water leakage, how do you modify it to make it works? i had thought to lay a thin layer of salt under it :-)
thanks
You might try this experiment:  soak a piece of paper in salt water, then let it dry out. After it's dry place it under the leak sensor. If the paper gets wet due to a leak it should trigger the sensor.
  • 2 months later...
Posted (edited)
Haha, so you want to know if your R/O system leaks. Must be RO/DI.
I get about 15ppm out of the RO (with permeate pump) and 1ppm after two stages of DI. Then re-mineralization cartridge to the little faucet and fridge. I have a valve and tube I can use to draw DI water for mixing up household cleaning solution, plants, etc.
It's suitable for a reef tank (which I don't have, no fishies in my high-rise condo, no thank you) and in fact I purchased from a company that specializes in that use.
(Reef tanks and saltwater aquariums best practice is go as close to 0 as possible, then add suitable minerals. I actually know somebody who has a business maintaining reef tanks. He was on an episode of Tanked!)
Edited by jtara92101
      37.7k
      377k
