interpreting program warning/error messages?
Going through several of my existing programs I now see comments added to the effect of "Warning:  Unrecognized Action (program may not run)
<cmd NODE="24801" ID="DOF"/>"   I believe but am not certain that some or all of these may have arisen when I updated to V5.3; however I'm not sure what to do with them?
Searching the Main/network window in the ACI can't find "nodes" with these numbers?   Is the node number irrelevant and what I need to do is check the program line right before the warning?
Have you recently deleted a scene?   I believe the looks like those attached to scenes.  DOF is the off action.
I recently accidentally deleted an insteon device while repurposing it.  I meant to remove it from the scene it was in but instead removed it from the ISY.  Then I just deleted the scene it was in.  Later I found programs with simmilar comments added IN PLACE of the previous scene commands.
