Programs stopped working after update
Manually updated to 5.0.16c. Fixes the out of memory issue, noticed none of my programs are running. In the summary run at start up has a dash on every program. Do i have to manually redo every program?
Sent from my SM-G960U using Tapatalk
No they dont. I clicked run on start for every program and now they seem to work. Keep everyone updated.
As always, clear your Java cache after an update and use the launcher from the update download page
If you enabled Run on Start for every program that's typically unneeded.  Depending on the program and what it does Run at Start may or may not create undesired behavior.  Typically ISY programs run on an event queue basis, "Run at Startup" forces an extra run at startup.
If the UI and Firmware versions don't match exactly then that's why programs look wonky.  Follow the instructions in the following thread to use The Launcher.  It will ensure that you are launching the correct version of the admin console for your firmware version.
