January 28, 20215 yr I currently have the isy944i system in place for my switches. My husband bought a garage system that operates through the hub. If I hook up the hub, can I get that to work for the switches too? Or do I have to start over again with the hub? Or is there a way to use them both?
January 28, 20215 yr 18 minutes ago, LMcGrath said: I currently have the isy944i system in place for my switches. My husband bought a garage system that operates through the hub. If I hook up the hub, can I get that to work for the switches too? Or do I have to start over again with the hub? Or is there a way to use them both? If you're talking about the insteon hub and you already have the isy, why not just add the device to the Isy instead of the hub
January 28, 20215 yr 52 minutes ago, LMcGrath said: My husband bought a garage system that operates through the hub. What is the "garage system"? Is it insteon garage door kit using the IOLinc?
