maximum subscribers reached
Hello! running 5.3.0.  When I log in to the admin Console i get error "maximum subscribers reached"
Also my instance of mobi linc pro on my iPhone keeps saying "Mobilinc disconnected. Attempting to reconnect to ISY"
I am also running:
- polisy box also looks to be working
- HA.  Which looks to be working .
Anyone ever seen this/ know a fix?
  • 4 months later...
I am also running:
Did you figure this out? I've just started having issues with subscribers loosing connections, UDMobile, and lots of -5012 errors in my error log.
Sent from my Google Pixel Slate using Tapatalk
I had same when I first moved to version 5. I solved it by deleting MobiLinc and it’s data from all mobile devices and adding it back.
Thanks, I don't use Mobilinc, but I find all my 5012 errors are coming from HueEmulator nodeserver which uses PyISY, and all others seem to be UDMobile loosing connections.  But, not sure why the connections are getting lost.
  • 3 weeks later...
My issue also seemed to be with Hue Emulator.  But i really cannot pinpoint this as I removed my Polisy nodeserver from my network and moved to Home Assistant.
