UD Mobile - iOS Alpha Testing
Javi
@Javi Just to follow up... whatever was causing my crashes you apparently fixed.  You'll remember I never had reproducible steps to fail, but whatever was causing is appears to be gone.
In programs, i do not understand the drop down for Enable, True, False.  I assumed that I could use the drop down to disable a program, choose disable, but that does not appear to work.  What is the drop downs purpose?
Are you using iOS?  (you did post in an iOS thread)  I just tried enabling/disabling a program, I had no trouble doing so--it works for me, although it uses a "dialog box" rather than "dropdown", so I wondered if you meant iOS or confused the terminology.
I am using IOS.  I will try again
      378.3k
