UD Mobile - iOS Alpha Testing
Hi All,
UD Mobile for iOS is now available for public testing.  Minimum firmware required 5.0.16.
https://testflight.apple.com/join/xHtzI5R3
Hi [mention]Javi [/mention]
Is this forum the preferred way to submit feedback and comments on the iOS beta?
I’ve installed it and like many things about it so far. Hope to try and crash it soon [emoji1787]
@Javi Just to follow up... whatever was causing my crashes you apparently fixed.  You'll remember I never had reproducible steps to fail, but whatever was causing is appears to be gone.
In programs, i do not understand the drop down for Enable, True, False.  I assumed that I could use the drop down to disable a program, choose disable, but that does not appear to work.  What is the drop downs purpose?
Are you using iOS?  (you did post in an iOS thread)  I just tried enabling/disabling a program, I had no trouble doing so--it works for me, although it uses a "dialog box" rather than "dropdown", so I wondered if you meant iOS or confused the terminology.
I am using IOS.  I will try again
