Getting this error. Was working great for a while. Screenshot_20210220-084128_UD Mobile.jpg
Sent from my SM-G960U using Tapatalk
Hi @diggler,
The error appears to show an invalid device address (C 63 EC 1).  Please post an image of this same screen with the header showing the device address (top left), and let us know your ISY firmware version.  This image does not need to show the error. I want to check if the app has a valid address or if the address is being changed when sending the command.
If this started after a sync, please reboot the ISY then resync.
Firm. 5.0.16. Not home. Will reboot when i get home and checkScreenshot_20210220-095308_UD Mobile.jpg
Reboot didnt work. Gonna hv to try n do the update
It worked when i first installed it. Went to use it a few days ago and it stopped.
Does this happen on the local network also (setting>system>name>advance)?
If it doesn't, or if unable to connect to the local network please logout of the portal account (setting>ISY Portal Accounts>Name> Delete). Then go back to you system and add login (setting>systems>name).
If that doesn't work we can schedule a remote session to diagnose.
I deleted the old portal. Go to add the portal back and get this message Screenshot_20210220-193800_UD Mobile.jpg
Updated to 5.3.2 and still getting error.
So im the idiot. I renewed my license but the payment never processed. Finally got home and checked my portal account and had to renew. Now works good. Sorry to waste ur time.
