Venstar thermostat issue
I have a Venstar T1800 thermostat with an ISY99.
I just started using heat for the first time since installation. Cool has worked correctly according to my program for the last 8 months.
I cannot seem to set the thermostats to heat through the ISY99. The webpage display changes when I toggle to heat and/or adjust the setpoint. But when I query the thermostat, the setpoint goes right back to where it began.
I just tried to set the thermostat mode to auto and the mode and setpoint seem to "stick".
Could there be a wiring or installation error ?
Hi legalguy,
Please upgrade to either of the following firmware:
1. 2.7.6 Beta (http://forum.universal-devices.com/viewtopic.php?t=3007) OR
2. 2.7.7 Alpha (http://forum.universal-devices.com/viewtopic.php?t=930)
Can you give me a bit of direction please.
I downloaded 2.76 - did not unzip per instructions
Tried to log in with isy - autoupdate - did not work
Logged in with my normal login
Tried to manually upgrade
Got error message: Upgrade Failed:Invalid or incompatible upgrade file
Be sure you are downloading the correct upgrade file. Note that there are 2 files - one for the ISY-26, and another for the ISY-99.
Be sure to read the upgrade instructions carefully. In short, be sure you are on a stable network connection (wired if possible) and disable any anti-virus/firewall software you might be running.
I got it now.
The new thermostat programming for Auto Mode works great.
