thermostat fan mode
insteon thermostat fan mode is not available in UD Mobile even though it is working in isy stock GUI
Edited by CandC
Hi @CandC,
Please try to resync the app, do you receive any errors?  If no errors are presented please open a Ticket and ask for Javier and we can diagnose the issue.
The app uses the Insteon Node Server files from the editor, opposed to hard coded values in the Web UI, so if a sync does not fix the issue we will have to check the files on the ISY.
syc finished with error but fan mode is now available
UD Mobile works great for me: Thanks! slot #3 is MQTT
