Changed port 443 to 80, now lost access to web interface.
Went to access my Polisy, and forgot all about needing to access via HTTPS port 443, after doing a port scan I remembered it. Well I was screwing around in my system settings..... (yeah I know... but I am a geek so I cannot help it), I thought "why don't I enable communication to the unit on port 80" Well I changed the setting on the system tab from port 443 to port 80, now the unit rebooted and I can only see port 22 and 123 (whereas before I could see ports 22, 123, 443, 9090 and a few others).
How do I change the default Polisy port back to port 443 from SSH?
Looked over the Polisy debug log for today... and I did something because this is what it is now filling with:
6/7/2021, 19:39:34 [polyglot] info: Starting Polyglot....
6/7/2021, 19:39:34 [polyglot] info: Settings: Polyglot Version 2.2.13
6/7/2021, 19:39:34 [polyglot] info: Settings: Retrieved config from database
6/7/2021, 19:39:34 [polyglot] info: Running in Polisy mode
6/7/2021, 19:39:34 [polyglot] info: Settings: Retrieved config overrides from .env and updated database
6/7/2021, 19:39:34 [polyglot] info: Aedes MQTT Broker Service: Started on port 1883
Same thing every 7-8 seconds.....
Is there a way to fix this from SSH
If you don't find a way, you may need to do a rest:
Multi Function Button
There's a little multi function button behind the very small hole on the front of the unit. This button has multiple purposes outlined below. Every click on the button will cause the unit to beep.
If the button does not behave as described below, please update Polisy.
Update and Upgrade All the Packages
Click the button once.
Safely Reboot
Click the button twice.
Safely Shutdown
Click the button three times.
Reset Credentials
Press and hold the button till the first LED (from the left) starts blinking then release. This action resets Polyglot as well as SSH credentials back to the default admin/admin.
Reset Networking
Press and hold the button till the first and second LEDs (from the left) start blinking then release. This action resets all network configuration back to DHCP on the Ethernet jack next to the serial port. All other network interfaces shall be disabled.
Factory Reset
Press and hold the button till all LEDs start blinking then release. This action resets the credentials, removes all configurations from Polyglot/Polisy, and resets networking.
