Where do I find the definitions for the codes from Net Module Rules?
Hi folks,
My question is where or how do I find out the meaning of the numerical codes
for the Net Module Rules shown in the collection of these codes I have taken from
the ISY Error Log (the numbers at the end of the lines; 11, 27, 29, 38)?
I am working with a bunch of Network Resources to control my home theatre system.
And I am slowly working out most of the problems I've been having (such as getting
working IR codes from a Global Cache IP2IR module).
-140005     HTTP_CLIENT_READ_RESPONSE_FAILED
Sun 2021/06/20 10:31:43 AM    System    -140005    Net Module Rule: 11
Sun 2021/06/20 10:26:09 AM    System    -140005    Net Module Rule: 27
Sun 2021/06/20 10:26:10 AM    System    -140005    Net Module Rule: 29
Sun 2021/06/20 10:32:15 AM    System    -140005    Net Module Rule: 38
I'm guessing these numerical codes are generated from the HTTP CLIENT in the ISY
and that the ISY is just writing them to the error log. But in any case,
is there a document explaining what the codes mean?
I believe 11,27,29, and 38 refer to the ID number of the network resource that caused the error.  In other words it's telling you which Network Resource caused the error.
Thanks Mr. Bill, I have checked those numbers against my network resources and it seems very likely you are correct. They were the resources I was using at the time these error messages occurred. I'll have to watch carefully to see if I can figure out what I'm doing wrong. Perhaps I need more delay between commands.
