random command execution
Hi,
I'm trying to write a program which simulates a TV being on, using a dimmer (as part of my vacation programs).
This is what I currently have:
       Repeat 1 times (Random)
          Wait  3 seconds
          Wait  3 seconds (Random)
          Set 'LR LampLinc TV' 50%
          Wait  3 seconds
          Set 'LR LampLinc TV' 75%
          Wait  3 seconds
          Set 'LR LampLinc TV' On
I was hoping that the "Repeat 1 times (Random)" would work to randomly execute certain statements, but that didn't work so well. I guess the 'randomness' is between 1 and the value specified (was hoping it's 0).
Is there another way to randomly execute statements?
Heiko
Hi Heiko,
Repeating random (in your case) means that it would either repeat the block or not execute at all.
I think what you need is to use the Random function on Wait instead of repeat. This way, the amount of time waited for the next statement will be random.
Hi,
          Wait  3 seconds
          Wait  3 seconds
          Wait  3 seconds
Heiko
That's exactly what I want, randomly executing the block (or not). Unfortunately it doesn't seem to work, it always executes all the blocks.
Using Wait is my backup solution, but this would cause my TV simulation not to be random. It would always go from 50%, to 75%, to 100%. I could probably make the code a bit more extensive, so it looks more random.
Heiko
