Polisy Rude Network Behavior
I use and enjoy my ISY every day.
However, polisy is acting rudely on my network.
Thousands of DNS queries to my.isy.io, proxy.isy.io, proxy2.isy.io.
Yesterday ran pkg update upgrade.  Today my pihole reports 51K queries to my.isy.io from my polisy box. seems like every 2 seconds
2021-07-06 17:55:40    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.2ms)
2021-07-06 17:55:37    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.2ms)
2021-07-06 17:55:36    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.1ms)
2021-07-06 17:55:35    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.2ms)
2021-07-06 17:55:33    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.2ms)
2021-07-06 17:55:32    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.3ms)
2021-07-06 17:55:30    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.3ms)
2021-07-06 17:55:28    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.2ms)
2021-07-06 17:55:21    A    my.isy.io    192.168.1.194    OK (cached)    IP (0.2ms)
Cold rebooted polisy.  Still multiple rapid DNS queries.  (my network topology has not changed)
Suggestions?
Hi,
Thanks for the quick reply.
A suggestion - Polisy should be respectful of the network whether it is successful or not in connecting.
Use a fallback mode, for example:
Try to connect every second for 1 minute
Try to connect every minute for 5 minutes
Try to connect every 10 minutes for an hour
Try to connect every hour for as long as polisy is booted.
After 1 hour - send an email alert to the administrator that connection is unsuccesfull.
  • 4 weeks later...
Also, it should be respecting the DNS and caching the results for the TTL specified time...
edit: Guess I should have checked the DNS first ... Why is the TTL for a CNAME to an AWS ELB set to 59seconds ?
Edited by albrandwood
