ISY on Polisy v5.0.1 - OUTDATED
Hello all,
Just so that we streamline version numbers (with ISY) and give less grief to Polyglot, please upgrade to 5.0.1:
Hello all,
To get started:
- sudo pkg update
- sudo pkg upgrade (this should upgrade your ISY to 5.0.1)
_ sudo service udx restart
- sudo service isy restart
Admin Console:
1. Use the Launcher
2. Click on the Add button and then enter the https://x.y.z.w:8443/desc or http://x.y.z.w:8080/desc where x.y.z.w is the IP address for your Polisy
3. Click on the Polisy row and this will bring up the Admin Console
4. If you are using INSTEON, since INSTEON is disabled by default:
- Admin Console | Configuration Tab | System
- Check INSTEON Support checkbox
- Click on the Save button and then Reboot button (restarts the ISY service)
Polyglot Settings:
1. Address/Hostname: localhost
2. Port: 8080
3. Username/Password for your ISY
4. Use HTTPS: unchecked
NOTE: Polyglot does NOT allow connection to HTTPS sites with self signed certs. For now, please only use port 8080 and localhost (do not use the IP address).
Fixes:
1. Not connecting to Polyglot
2. Network module is now enabled by default so that you no longer need the ISY Portal Module
Enhancements:
1. OpenADR support by default
