TJF1960 Posted July 24, 2021 Share Posted July 24, 2021 Have Acuparse on rpi4 and is sending to polyglot on rpi4. Working great. Backed up poly on rip and used that file to restore on Polsy. noticed Weatherpoly not running. since ISY on polisy is set to port 8080 I changed the port for weather to 8088. It now runs but not getting updates from Acuparse. set Acuparse to send to http://192.168.0.27:8088/acuparse Does anyone have it running on Polisy? isy v5.0.5 polisy poly latest. Thanks, Tim Link to comment Share on other sites More sharing options...
bpwwer Posted July 26, 2021 Share Posted July 26, 2021 I don't have acuparse so can't try and reproduce, but there's nothing in the node server that would be different between running on a RPi or a Polisy. Do you have a firewall running someplace that may be preventing requests making it to the Polisy? The node server is running a simple webserver to get the data. You should be able to make the request from any browser, just put in the URL with some random data. If I do something like this: http://192.168.92.12:8088/acuparse?temp=23 I'll get a response, successful data submission in the browser window Link to comment Share on other sites More sharing options...
TJF1960 Posted July 27, 2021 Author Share Posted July 27, 2021 Thanks Bob, I will give that a try and see what happens. Tim Link to comment Share on other sites More sharing options...
TJF1960 Posted July 27, 2021 Author Share Posted July 27, 2021 When I enter http://192.168.0.27:8088/acuparse?temp=23 the webpage comes back with successfull data transmission. However it isn't logged in poly. And node ST doesn't change to reflect temp. Here is the log file from start time. 2021-07-27 05:06:48,767 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-07-27 05:06:49,394 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-07-27 05:06:49,395 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-07-27 05:06:49,579 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.0.1', 'igb0')}, 2: [('192.168.0.1', 'igb0', True)]} 2021-07-27 05:06:49,580 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.0.1', 'igb0') 2021-07-27 05:06:49,581 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'}] 2021-07-27 05:06:49,582 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'} 2021-07-27 05:06:49,584 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-07-27 05:06:49,586 MainThread polyinterface INFO weatherstation:<module>: Calling Controller to create controller node 2021-07-27 05:06:49,761 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-07-27 05:06:49,763 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/8 - MID: 1 Result: 0 2021-07-27 05:06:49,764 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-07-27 05:06:49,765 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-07-27 05:06:49,801 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-07-27 05:06:49,820 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-07-27 05:06:50,363 NodeServer polyinterface INFO weatherstation:start: Starting WeatherPoly Node Server 2021-07-27 05:06:50,364 NodeServer polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2021-07-27 05:06:50,646 NodeServer polyinterface INFO weatherstation:set_logging_level: set_logging_level: Setting log level to 0 2021-07-27 05:19:10,421 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-07-27 05:19:11,561 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-07-27 05:19:11,562 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-07-27 05:19:11,618 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.0.1', 'igb0')}, 2: [('192.168.0.1', 'igb0', True)]} 2021-07-27 05:19:11,618 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.0.1', 'igb0') 2021-07-27 05:19:11,619 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'}] 2021-07-27 05:19:11,620 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'} 2021-07-27 05:19:11,621 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-07-27 05:19:11,622 MainThread polyinterface INFO weatherstation:<module>: Calling Controller to create controller node 2021-07-27 05:19:11,682 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-07-27 05:19:11,684 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/8 - MID: 1 Result: 0 2021-07-27 05:19:11,684 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-07-27 05:19:11,685 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-07-27 05:19:11,690 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-07-27 05:19:11,693 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-07-27 05:19:11,738 NodeServer polyinterface INFO weatherstation:start: Starting WeatherPoly Node Server 2021-07-27 05:19:11,739 NodeServer polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2021-07-27 05:19:11,969 NodeServer polyinterface INFO weatherstation:set_logging_level: set_logging_level: Setting log level to 0 2021-07-27 05:19:13,130 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'temperature' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'temperature' 2021-07-27 05:19:13,138 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'humidity' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'humidity' 2021-07-27 05:19:13,171 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'pressure' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'pressure' 2021-07-27 05:19:13,175 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'rain' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'rain' 2021-07-27 05:19:13,178 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'wind' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'wind' 2021-07-27 05:19:13,215 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'humidity' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'humidity' 2021-07-27 05:19:13,219 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'temperature' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'temperature' 2021-07-27 05:19:13,222 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'pressure' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'pressure' 2021-07-27 05:19:13,254 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'rain' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'rain' 2021-07-27 05:19:13,256 Controller polyinterface ERROR polyinterface:_handleResult: handleResult: 'wind' Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/polyinterface/polyinterface.py", line 878, in _handleResult del self.nodes[result['addnode']['address']] KeyError: 'wind' 2021-07-27 05:19:52,373 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-07-27 05:19:53,905 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-07-27 05:19:53,907 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-07-27 05:19:54,055 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.0.1', 'igb0')}, 2: [('192.168.0.1', 'igb0', True)]} 2021-07-27 05:19:54,056 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.0.1', 'igb0') 2021-07-27 05:19:54,057 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'}] 2021-07-27 05:19:54,058 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'} 2021-07-27 05:19:54,127 MainThread polyinterface INFO weatherstation:<module>: Calling Controller to create controller node 2021-07-27 05:19:54,145 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-07-27 05:19:54,629 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-07-27 05:19:54,632 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/8 - MID: 1 Result: 0 2021-07-27 05:19:54,633 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-07-27 05:19:54,634 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-07-27 05:19:54,727 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-07-27 05:19:54,773 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-07-27 05:19:55,106 NodeServer polyinterface INFO weatherstation:start: Starting WeatherPoly Node Server 2021-07-27 05:19:55,107 NodeServer polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2021-07-27 05:19:55,255 NodeServer polyinterface INFO weatherstation:set_logging_level: set_logging_level: Setting log level to 0 2021-07-27 05:22:21,544 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-07-27 05:22:23,133 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-07-27 05:22:23,134 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-07-27 05:22:23,210 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.0.1', 'igb0')}, 2: [('192.168.0.1', 'igb0', True)]} 2021-07-27 05:22:23,211 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.0.1', 'igb0') 2021-07-27 05:22:23,212 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'}] 2021-07-27 05:22:23,213 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.0.27', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'} 2021-07-27 05:22:23,215 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-07-27 05:22:23,216 MainThread polyinterface INFO weatherstation:<module>: Calling Controller to create controller node 2021-07-27 05:22:23,529 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-07-27 05:22:23,532 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/8 - MID: 1 Result: 0 2021-07-27 05:22:23,533 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-07-27 05:22:23,535 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-07-27 05:22:23,581 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-07-27 05:22:23,638 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-07-27 05:22:24,119 NodeServer polyinterface INFO weatherstation:start: Starting WeatherPoly Node Server 2021-07-27 05:22:24,121 NodeServer polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2021-07-27 05:22:24,470 NodeServer polyinterface INFO weatherstation:set_logging_level: set_logging_level: Setting log level to 0 Link to comment Share on other sites More sharing options...
bpwwer Posted July 27, 2021 Share Posted July 27, 2021 I don't see any messages in the log to indicate that it's been configured to parse any data. How do you have it configured? Link to comment Share on other sites More sharing options...
TJF1960 Posted July 28, 2021 Author Share Posted July 28, 2021 Thanks Bob. Once I looked over the configure table I realized I needed to add an f after temp in the string you suggested. Once added, the node did change to the value sent. So, http://192.168.0.27:8088/acuparse?tempf=23 command will change the temp value correctly. So, it appears that my problem is with Acuparse sending out to the Polisy. Thanks for your help in verifying WeatherPoly was not at fault Bob. Tim Link to comment Share on other sites More sharing options...
bpwwer Posted July 28, 2021 Share Posted July 28, 2021 The configuration of WeatherPoly is tricky. Polyglot's UI is pretty simplistic and trying to configure for multiple different weather software programs in a 'generic' way is complicated. Not a good fit. If I ever get some spare time, I'll try to come up with a better way to configure, but in the meantime, the shared knowledge here should help. Link to comment Share on other sites More sharing options...
