Mecheng70 Posted August 4, 2021 Share Posted August 4, 2021 Error: Component error: isy994 - cannot import name 'VOLT' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py) Updated from 2021.7.4 to 2021.8.0 and now isy will not load. anyone seeing this? Created an issue: https://github.com/home-assistant/core/issues/53969 It was mentioned: Quote I think you are using the custom integration (custom_components folder)... Not sure what this means. Here is my setup: configuration.yaml #################################################### # ISY 994 # #################################################### isy994: host: http://172.16.5.251:80 username: !secret isy994_username password: !secret isy994_password And the integration: I do have an isy994 directory under the custom_components folder. My question is, what do I do with it? Delete it? Link to comment
Mecheng70 Posted August 4, 2021 Author Share Posted August 4, 2021 @shbatm @bdraco Thoughts on this? Link to comment
Mecheng70 Posted August 4, 2021 Author Share Posted August 4, 2021 Fixed the issue by changing out FROM: VOLT TO: ELECTRIC_POTENTIAL_VOLT for 2 cases in the const.py file; line 101 and 398. Not sure why this is not updating with the core. Link to comment
Mecheng70 Posted August 4, 2021 Author Share Posted August 4, 2021 Or from @shbatm Quote Make sure you remove the ISY994 addon from HACS and/or remove the config/custom_components/isy994 folder. Everything from the custom component is in the current version of the core integration. also fixes the issue... and probably the best solution. Link to comment
