Emergency Button
Did you find this idea useful? 22 members have voted
  1. 1. Did you find this idea useful?
    • Yes
      90%
      20
    • No
      9%
      2
Please sign in or register to vote in this poll.
I implemented an "Emergency Button" that I think is worth sharing. I have two school age children that sometimes are home alone, but this idea has several applications.
To use it, they simply press the button. To reset, they press it a second time.
I wrote two simple programs called "Emergency" and "Emergency Clear" I use a KeyPadLinc-8 near the front door and will get a red button to activate it, both programs use "Status" is "On" to monitor the button in the 'if' area.
I have placed both my wife's and my phone text message as recipients for notifications.
The "Emergency" program 'then' area sends notification to all. The next line uses "Set Scene My Lighting On", turning on every light in the house. The 'else' area runs certain daily programs I have to restore "normal" settings (optional).
The "Emergency Clear" program 'then' area turns an outside front door light fast on, waits a second, turns it fast off, then calls itself as a program. In other words, the last line is 'Run Program Emergency Clear". This causes the program to loop continuously, flashing the front door light, attracting the attention of emergency responders if they are needed. The 'else' area only sends notification to all.
The messages received on the cell phone are pretty clear if the button is activated or reset. We can then take appropriate action to see what is going on.
Hope you like the idea!
  • 7 months later...
On a similar note,
I have a 911 Flash keypad button at the front door that flashes the outside lights if double-tapped (FastOn). It also sends me a text message. The flash program stops when the button is turned off or fastoff.
Really, instead of a flash, it uses a "repeat' routine with a large number of repeats. That way it will eventually time out.
I did this because one time we had an ambulace come to the house and they couldn't find the place. Now I can tell 911 to look for the flashing lights.
  • 3 weeks later...
I would also be interested in the code if you are willing to share.
Mike
One example. This one repeats until the KPL button is turned off.
       Control 'KPL C' is switched Fast On
   And Control 'KPL C' is not switched Off
   And Control 'KPL C' is not switched Fast Off
       Send Notification to 'Sub-Routine'
       Repeat Every  1 second
          Set Scene 'All Lights' On
          Set Scene 'All Lights' Off
If you want to limit the number of flashes you can use a Repeat X times:
       Control 'FR KPL Tracks / FR KPL C Fan' is switched Fast On
   And Control 'FR KPL Tracks / FR KPL C Fan' is not switched Off
   And Control 'FR KPL Tracks / FR KPL C Fan' is not switched Fast Off
       Repeat 10 times
Rand
If you don't have the two "And's" in the "If" statement will it just continue without ever turning off even after the button is shut off?
I guess I just figured if the switch was turned off it wouldn't run anymore. But with the program I have it does seem to just keep running and running even after the button is shut off. This might be the problem.
Mike
Hi Mike,
I think you have already discovered that the program will run forever after it sees the switch turned on.
The not switched Off is indeed the condition that will cause the program to be reevaluated and fall through to the Else actions, of which there are none in this example, so it will effectively quit.
The Else actions could include changing the lights back on to their normal settings and without a Repeat would just do that and terminate.
While my example calls All Lights I would suggest a scene with only the lights you want to flash; driveway, front door, etc.
Rand
I knew I was having a looping problem but I didn't realize this is where the problem was coming from and I haven't had much time to play around with it.
But it make since when you remember that the isy doesn't poll any information so an event has to happen that it is looking for before it shows a change.
Thanks again,
Mike
Looking over things and just had a quick question.
I have a 4 year old bedroom closet program to keep the light from being left on all day in his closet:
       Control 'Closet Light' is switched On
       Wait  5 minutes
       Set 'Closet Light' Fast Off
Once this program runs the status of the program remains true. Do I need to do something like this?
       Wait  5 minutes
       Set 'Closet Light' Query
So that it knows the light is off now and the program will show false and look for the light to be turned on again? Just trying to wrap my head around this non-polling idea.
Mike
Hi Mike,
Since you are using Control as a condition the program will start whenever the switch is pressed On. Remaining True will not be an issue. A Query will not change the status of that program. You could add an action that Run (Else) the program which would turn it False but it is not necessary.
You may rather look at Last Run Time in the Program Summary to see exactly when it was last triggered.
Rand
