External Power Adapter Voltage for an ISY99i
I was under the impression that the external optional power supply should be 5 volts 300 ma.
I posted that data in the Smarthome forums on using the new 2413S Dual band PLM. Since it does not supply power like the older 2412S PLMs unregulated twelve volts.
Their Administrator Isaac told me I was incorrect and UDI said five to thirty volts was OK.
Can you verify which is correct.
Hi Brian,
Yes, this is correct. You can supply ISY with up to 30 volts and it should work fine.
The minimum is 5Volts, 300 mA, and 2 mm barrel connector.
