dbwarner5 Posted September 17, 2021 Share Posted September 17, 2021 Have been using it successfully for a month or so. ISY is talking with Polisy and showing what is in the polisy. However, Polisy is NOT showing what is on the tempest. Any suggestions? I have restarted it a few times. No change. Thanks, Link to comment Share on other sites More sharing options...
bpwwer Posted September 17, 2021 Share Posted September 17, 2021 What does the log show? Link to comment Share on other sites More sharing options...
dbwarner5 Posted September 18, 2021 Author Share Posted September 18, 2021 2021-09-18 10:37:06,212 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-09-18 10:37:07,301 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-09-18 10:37:07,303 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-09-18 10:37:07,707 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.68.1', 'igb0')}, 2: [('192.168.68.1', 'igb0', True)]} 2021-09-18 10:37:07,708 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.68.1', 'igb0') 2021-09-18 10:37:07,709 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.68.76', 'netmask': '255.255.252.0', 'broadcast': '192.168.71.255'}] 2021-09-18 10:37:07,710 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.68.76', 'netmask': '255.255.252.0', 'broadcast': '192.168.71.255'} 2021-09-18 10:37:07,712 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-09-18 10:37:08,205 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-09-18 10:37:08,210 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/1 - MID: 1 Result: 0 2021-09-18 10:37:08,211 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-09-18 10:37:08,212 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-09-18 10:37:08,424 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-09-18 10:37:08,747 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-09-18 10:37:09,223 NodeServer polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2021-09-18 10:37:09,224 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2021-09-18 10:37:09,225 NodeServer polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 30 2021-09-18 10:37:09,227 NodeServer polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2021-09-18 10:37:09,228 NodeServer polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2021-09-18 10:37:09,366 NodeServer polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 30 2021-09-18 10:37:09,729 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 1 2021-09-18 10:37:09,783 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 2 2021-09-18 10:37:09,843 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 3 2021-09-18 10:37:09,901 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 4 2021-09-18 10:37:09,956 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 5 2021-09-18 10:37:10,013 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 6 2021-09-18 10:37:10,411 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/nodeservers/WeatherFlowPoly/nodes/weatherflow.py", line 769, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) OSError: [Errno 48] Address already in use 2021-09-18 10:37:10,414 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2021-09-18 10:37:10,414 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2021-09-18 10:37:41,482 MainThread polyinterface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2021-09-18 10:37:42,677 MainThread polyinterface INFO polyinterface:init_interface: Received Config from STDIN. 2021-09-18 10:37:42,678 MainThread polyinterface INFO __init__:<module>: UDI Polyglot v2 Interface 2.1.0 Starting... 2021-09-18 10:37:43,085 MainThread polyinterface DEBUG polyinterface:get_network_interface: gws: {'default': {2: ('192.168.68.1', 'igb0')}, 2: [('192.168.68.1', 'igb0', True)]} 2021-09-18 10:37:43,086 MainThread polyinterface DEBUG polyinterface:get_network_interface: gw: default=('192.168.68.1', 'igb0') 2021-09-18 10:37:43,088 MainThread polyinterface DEBUG polyinterface:get_network_interface: ifad: igb0=[{'addr': '192.168.68.76', 'netmask': '255.255.252.0', 'broadcast': '192.168.71.255'}] 2021-09-18 10:37:43,088 MainThread polyinterface INFO polyinterface:__init__: Connect: Network Interface: {'addr': '192.168.68.76', 'netmask': '255.255.252.0', 'broadcast': '192.168.71.255'} 2021-09-18 10:37:43,091 Interface polyinterface INFO polyinterface:_startMqtt: Connecting to MQTT... localhost:1883 2021-09-18 10:37:43,654 MQTT polyinterface INFO polyinterface:_connect: MQTT Connected with result code 0 (Success) 2021-09-18 10:37:43,657 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/ns/1 - MID: 1 Result: 0 2021-09-18 10:37:43,657 MQTT polyinterface INFO polyinterface:_connect: MQTT Subscribing to topic: udi/polyglot/connections/polyglot - MID: 2 Result: 0 2021-09-18 10:37:43,659 MQTT polyinterface INFO polyinterface:_connect: Sent Connected message to Polyglot 2021-09-18 10:37:43,881 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2021-09-18 10:37:43,999 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-09-18 10:37:44,490 NodeServer polyinterface INFO weatherflow:start: Starting WeatherFlow Node Server 2021-09-18 10:37:44,491 MQTT polyinterface DEBUG weatherflow:process_config: -- configuration is valid 2021-09-18 10:37:44,491 NodeServer polyinterface ERROR node_funcs:get_saved_log_level: Found saved log level 30 2021-09-18 10:37:44,493 NodeServer polyinterface ERROR node_funcs:save_log_level: saving log level to customdata 2021-09-18 10:37:44,493 NodeServer polyinterface INFO polyinterface:saveCustomData: Sending customData to Polyglot. 2021-09-18 10:37:44,642 NodeServer polyinterface INFO node_funcs:set_logging_level: set_logging_level: Setting log level to 30 2021-09-18 10:37:45,009 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 1 2021-09-18 10:37:45,067 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 2 2021-09-18 10:37:45,130 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 3 2021-09-18 10:37:45,186 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 4 2021-09-18 10:37:45,244 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 5 2021-09-18 10:37:45,303 NodeServer polyinterface ERROR weatherflow:query_wf: Failed to get rain for month 6 2021-09-18 10:37:48,719 Thread-1 polyinterface ERROR polyinterface:write: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/nodeservers/WeatherFlowPoly/nodes/weatherflow.py", line 769, in udp_data s.bind(('0.0.0.0', self.params.get('ListenPort'))) OSError: [Errno 48] Address already in use 2021-09-18 10:37:48,720 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> 2021-09-18 10:37:48,720 Thread-1 py.warnings WARNING warnings:_showwarnmsg: /usr/local/lib/python3.7/threading.py:960: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 0)> Link to comment Share on other sites More sharing options...
dbwarner5 Posted September 18, 2021 Author Share Posted September 18, 2021 if easier, here is a ZIP file of it. WeatherFlowPoly_logs_9-18-2021_103926_AM.zip Link to comment Share on other sites More sharing options...
bpwwer Posted September 18, 2021 Share Posted September 18, 2021 1 hour ago, dbwarner5 said: OSError: [Errno 48] Address already in use Something else running on that machine is already listening for WeatherFlow data and has been configured for exclusive use. This blocks the node server from receiving data from the hub. Link to comment Share on other sites More sharing options...
dbwarner5 Posted September 19, 2021 Author Share Posted September 19, 2021 On 9/18/2021 at 11:45 AM, bpwwer said: Something else running on that machine is already listening for WeatherFlow data and has been configured for exclusive use. This blocks the node server from receiving data from the hub. Hmm.. not sure where to start with that information. Can you define "machine"? is that the isy, the tempest hub or the polisy? As far as I know the only thing running on the tempest hub is the polisy and the tempest app. Any suggestions to move forward? thanks Link to comment Share on other sites More sharing options...
bpwwer Posted September 19, 2021 Share Posted September 19, 2021 Machine is the machine the node server is executing on, in this case the Polisy. The log shows that something external to the node server is blocking the node server such that it can't open the socket connection needed to listen for data from the hub. When run on RPi instead of Polisy, this would typically be caused by some other weather software, but that shouldn't be the case the on a Polisy. Thus, I really don't know what to do next. I don't know enough about the FreeBSD OS running on the Polisy to know if this could be a network configuration issue, a bug, or some other software running on the Polisy that's impacting this. I do know that this is normal since many people, including me, run this on a Polisy without any issues. Googling the error provides this: Quote Simple solution: 1. Find the process using port 50222: sudo lsof -i:50222 2. Kill the process on that port: kill $PID kill -9 $PID //to forcefully kill the port PID is got from step 1's output. so you could try that. Link to comment Share on other sites More sharing options...
dbwarner5 Posted September 21, 2021 Author Share Posted September 21, 2021 Update.... turns out my whole polisy was not working properly. Had to unplug it and replug it in. Now its working correctly. so it may have been itself in an older form blocking the socket. All is well again.. thanks for your programming and support efforts! @bpwwer Link to comment Share on other sites More sharing options...
