Polisy ISY Configuration Removal???
pizzdov
I have polisy unit that I have updated to 13...
I have run sudo pkg update; sudo pkg upgrade; sudo service udx restart; sudo service isy restart.
uname -a reports FreeBSD polisy 13.0-RELEASE-p4.
udx is on 2.4.3.5.
isy is on 5.0.4_36
service isy status => isy running as pid 1124.
I was able to get the ISY Finder to see the ISY service at IP:8443/desc.
I was able to get to the admin panel at IP:8443/desc.
I tried to Restore a backup off my ISY994i with the admin panel at IP:8443/desc.  It appeared to by cycling through the backup normally.  I see now that it appears this is not a supported activity...
Now, I can no longer connect to IP:8443/desc.  ISY Finder does not fill in the Type/Version.
Is there anyway to wipe the ISY configuration on the Polisy, so I can start over clean?  Factory reset did not help.
Found /var/isy directory on polisy which appears to have the configuration in FILES.... What can a remove?
Thanks in advance
Thank you... I will give that a try.
It is hard to tell from all the posts I find:
Is the ISY running on the Polisy with USB PLM a stable incantation now?
Is there a way to migrate the ISY-994i configuration to the Polisy ISY without having to start completely over; ie I have probably 100+ devices/switches/scenes/programs, etc?
      380.4k
