Error -- Adding device to scene imcomplete
Michel,
Thanks for your help eariler today. I was trying the trick you showed me to remove an orphaned link from a device pointing to a Remotelinc button by adding the RL button and device to a scene, however I'm getting the following error.
[-200000] Adding device to scene imcomplete [(my device name)]
I tried adding the RL button first and second and still get this message.
Any suggestions?
Hi fasttimes,
Apologies for a tardy reply.
Yes. Please use Event Viewer/Level 3 to figure out which device is causing this issues. In most cases the problem is signal. In 10% of the cases the problem is the device itself refusing to write to a specific memory location. Factory reset fixes this issue.
Michel,
Any suggestions?
