Ambient Weather Release Notes
The latest release is version 2.0.1.
  • This is the first release that supports PG3. The node layout has changed from PG2 versions of the Ambient Weather node servers. You likely need to fix any programs that are based on Ambient Weather data when migrating to PG3.
Pulls data from http://www.ambientweather.com and makes it available to the ISY.
This node server uses an API Key associated with your ambient weather account to query the ambient weather servers for your weather stations.  Supports multiple weather stations with multiple sensors.  Nodes will be dynamically created for each station and each sensor attached to the station.
The ambient weather servers are polled at the short poll interval (in seconds).  The servers do rate limit so it is recommended to poll at a minimum of 60 seconds.
