Proper to remove Polisy
I need to remove Polisy from my environment.  I had a few nodes setup.
Can someone please offer best practice to get myself back to pre-polisy state?
In the Polisy Dashboard, select "Details" for each nodeserver, and then the "Nodes" button, and here delete the nodes for each nodeserver, deleting the Controller node for each nodeserver last. You may then delete the nodeservers from  your Polisy using the "Delete"  button (again under Details).
Then just shutdown the Polisy - you're done.
NOTE: You could try just Deleting each nodeserver - that may work without having to delete the individual nodes.
Edited by Goose66
