Sunset/Sunrise (Next Day) issue
Since my PLM bit the dust and I received the USB version I am officially moving to ISY on Polisy. I shut down my ISY994i and decided that I am going to stick with the Polisy version of ISY. So, after getting through some speed bumps with the help of support I am moving on. I am setting up Polisy one device at a time. For me it was time to move on.
I may have encountered my first device/program issue and it includes Sunrise/Sunset (Next Day) with a Motion Sensor II.
Program 1: The basic program works perfectly WITHOUT Sunset/Sunrise.
Program 2: Added Sunset/Sunrise and the Car Port light comes on, but does not turn off. Tried reversing the order of sunset/sunrise and motion sensor in the "IF", with no luck. Worked fine on the old ISY.
PGM-1
Lights - Car Port - [ID 000D][Parent 0001]
        'Motion Sensor - Car Port' Status is On
        Set 'Lights - Car Port - On-Off Mo' On
        Wait  1 minute and 15 seconds
        Set 'Lights - Car Port - On-Off Mo' Off
PGM-2
    And From    Sunset
        To      Sunrise (next day)
Check the top of your admin console and see if you are located in LA Cal.
Miami,  and the Sunrise time and Sunset time is/was correct.
Dunedin,
Howdeeee
