Samsung TV serial command formatting via Global Cache iFlex Serial
I have a Samsung TV which is controlled by a Global Cache iFlex serial adapter.  I can send commands to the TV via the global cache iTest application and everything works, but I cannot figure out the correct sytax to control via the ISY Network Resources.  I attached 2 screen grabs of successful "PowerOn" and "PowerOff" commands sent using iTest.  One is sent as Hex and the other as Mixed (whatever that is).  But I can't seem to find anything that works from the ISY.  I have other components that I control via a iFlex serial adapter, but I don't think any of them use hex format.
Mike
image.png.fe254c2ae3e91f705ae53d9fd7a46d71.pngimage.png.139b42d1fc76d853016312204afde7df.png
Edited by mvp119
Awesome!  Thanks so much. That worked!  I tried searching the forums multiple times for the solution but couldn't find it...
See:
Quick with the draw! I recently did the same thing and referred to that post.
