Scene with network resourcec
Just getting some TP-Link (Kasa) into network resources, and wanted to add them to a christmas lights scene.  I'm on 4.9 so no ability to get to advanced 5 features yet if that is possible There.
Started with trying to add a program to look for control of the 8 pad button press C for christmas, but program did not trigger when I turned them on at the keypad.
Question #1... if you open the admin conole to node for Button C do you see button C turning on and off in the admin console?
Questions#2.. did you test your network resource to ensure that it's set up correctly?
Additional info: remeber that you can select the program name in the program tree and then right click and pick Run THen or Run Else to test your program.  Also remember that you must SAVE the program before it will work, or save to apply changes before they will take effect.
