Program Folder Conditions - Question
Firmware        Insteon UD994 v.5.3.4 (2021-07-07-14:46:02)
UI                    Insteon UD994 v.5.3.4 (2021-07-07-14:46:02)
Product           ISY 994/IR PRO (1110)
-        OpenADR (21010)
-        Z-Wave (21100)
-        Portal Integration – UDI (21075)
I have a question about how Program Folder conditions should work.
Current values:
·       Integer variable “Guests” value is 1
·       For Program Folder “GUEST” the IF condition is “$Guests is 1”
·       Within the Folder “GUEST” is a program “Guest_Run” where the THEN statement is ‘Set FamRm Lights’ On
Situation:
When I run a program that has no IF conditions where the THEN statement is “Run Program ‘Guest_Run’ (Then) – sometimes the program within the GUEST folder will run, sometimes it will not run. The Folder Condition for the GUEST folder is not consistently/accurately allowing or disallowing the program within the folder to run.
Should Folder Conditions work correctly to allow/disallow when a THEN statement in a program within the Folder with the condition is called from another program?
Any advice is appreciated and Happy New Year.
