What is the difference between the Polisy java finder and the ISY java finder?
I looked around and couldn't find an answer to this, so I figured I would ask here in case others have this question in the future.
I see there are two different java finder/admin apps.  One for ISY and one for Polisy.  As far as I can tell both of them work with ISY on Polisy.  I assume we should use the Polisy version?  I am asking because the ISY version works slightly better on my mac since it created a desktop shortcut while the Polisy one did not, so I am using the ISY version for now.  Is that a problem?
I'm guessing that @smileyw is confusing "ISY Launcher" (filename start.jnlp when downloaded) and a copy of admin.jnlp which is a specific version of the admin console.
ISY Launcher (start.jnlp) adds an Icon to the desktop named ISY Launcher.   When using it, it should get the correct the correct version of the admin console.
The first thing that you see whether using the ISY Launcher or admin.jnlp is "ISY Finder".
Edited by MrBill
One is called the "Polisy administrative console" while the other one is called "ISY Launcher".  I am not sure where I even got the Polisy one in the first place.  Either way, I will just stick with the ISY finder.  I was just assuming that if there was one that was called Polisy, it made sense to use it for the ISY on the Polisy.
I use the ISY Launcher but got the Polisy Administrative Console from this post:
