I have no scenes or programs and timers running. Theres a flashing red led on my ISY
And it doesn't show up in the ISY Launcher.
Any help would be great.
I started this issue over here...
but it seems to be more than that so I started this thread
Drew
Internet is on
Is there a procedure for unplugging or just unplug for a minute then plug back in?
This happened once before and the Powerline modem burned out, this is why I'm cautious about this
(Just unplugged and plugged back in. everything seems to be working fine. Thanks for the help)
Edited by andrew77
From the Wiki:
Quote
  • Only Error light blinking: ISY cannot communicate with the SD Card. Please ensure:
    • The micro SD Card (on the front) is seated properly. Unplug ISY, remove the rubber cap, using a sharp object, push the micro SD Card in so that it pops out. Push it back in so it clicks in. Apply power to ISY
    • If reseating the micro SD Card does not work, you probably have a defective SD Card. Please consult Replacing/Formatting SD Card
Sounds like you either need to re-seat or replace the SD card.  If you have to order one up to 32gb will work (the wiki however says 16gb) and look for the newer A1 rating.  (A2 rating won't help as it requires hardware support that the 994 doesn't have.)
      376.5k
