Sequential delays - best way?
Hi, new to ISY99 and converting my lighting from Homeseer. So far I am finding ISY makes it easier to do the things I want with my lighting.
I have just been going thru my Homeseer "Events" and converting them to ISY programs.
I have a few Events (such as Sunset) that I want to turn on individual lights and scenes in sequence over a period of time.
I have simply created an ISY program using the "Wait" command between "Set" statements to create the desired delays (see the Code example) - is there a better way to accomplish this? Does this approach unnecessarily use processing resources? Rather than the one Program, should I break this up into several Programs for each of the time triggers?
Also, based on the little testing I've done so far, the Wait commands appear to run in sequence and are cumulative within the program. This differs from Homeseer where each item in the event can have an explicit ON and/or OFF delay associated with it.
Rob
       Time is Sunset  - 20 minutes
       Set 'GreatRoom:Sconce' On
       Wait  5 minutes  (Random)
       Set 'GreatRoom:Peninsula KL-Pendan' 35%
       Set 'GreatRoom:Side Table Lamps' 25%
       Set Scene 'MasterBed:Table Lamps Scene' On
       Set Scene 'Global:All Ext. Coach Scene' On
       Send X10 'D6/On (3)'
       Set 'Porch:Xmas Icicle' On
       Wait  30 minutes
       Set Scene 'Global:All Ext. Floods Scene' On
       Wait  1 hour
       Set 'Flood:Driveway' Off
Hi Rob,
Welcome!
If you want the events to be in that sequence then the program you have is the best way to do it. And, you are not using more processing power than spitting it into more programs.
Waits are simply constructs that put the execution of a program (as a whole) in a queue to woken up after that period ends.
