Failure to connect FYI
It looks like sometime in the last day or so I started to get a failure to connect error. Restarting the node server seems to have fixed it.
I had a similar problem with the flume node server a few days ago. It also said unexpected disconnection.
This is an FYI as I know everything is in beta. I have a bit of the logs below. If you need more info  let me know.
That usually means your RainMachine can't be reached on the network.
about 80% sure that it was reachable...I could connect via a browser to it. Anyway no big deal. I will keep an eye on it and let you know if I figure out anything.
