2.4.13 - Synch Clock if using sunrise/sunset (DST)
If you are using sunrise/sunset in any of your programs, please go to the 'Configuration' Tab and 'Synchronize the Clock with Computers Time'.
As part of the scheduler processing, we pre-calculate the sunrise/sunset for the next 14 days. Whenever the time is synchronized or changed, we recalculate these values. Unfortunately for the DST changeover we did not recalculate them.
This is fixed in the next code drop.
We need NTP time support in the ISY, so that the ISY always has the correct time...
You could select manual or automatic..
manual would be what you have today..
if automatic, let the user set the NTP name or ip address... this is what is done in most routers and computers today. No need for a default list.
see below for current method of setting POOL servers...
http://support.ntp.org/bin/view/Servers/NTPPoolServers
lafleur,
Yes, we actually had this fucntionality and removed it due to pool servers not responding (once in a while) and thus causing problems. It's on our list of bugs to look at.
Thanks so very much,
