NodeLink Server v0.11.2 - Unable to update node definitions in ISY on Polisy
I updated my Nodelink server (running on a Raspberry Pi) to V0.11.2.  I couldn't get the upgrade to fully execute by hitting the "Check for Update" button on the System Config page, so I just re-ran the install script and that seemed to take care of it.
However, it seems like there is still an issue with not being able to update the node definitions on an ISY running on a Polisy device.  It tries to update them, and says they were updated successfully, but restarting Nodelink continues to present the same error indicating they need to be updated (see screenshot below).
That's a question for UDI.  I've adjusted the case to match polisy (against what the wiki says).  Something else is different with polisy.
@JaviIs the filename or xml extension also lowercase?
The file names match rest/profiles/family/<familyNumber>/profile/<profileNumber>/files.  However something looks off with the family and profile number, unless the Node Server developer copied the Insteon File Names.
Can you post the response of rest/profiles/family/10/profile/11/files ?
Nevermind, we worked it out.  Everything needs to be lowercase including the filename.
