Transfer from PGC to Polisy
NOT an expert here....
Since PGC is down for the duration, I ordered a Polisy.
For the time being, I just want my new Polisy to connect with the ring servers and my existing ISY994.  Currently whenever certain ring cameras detect motion, it turns on a series of Insteon lights.
Is there a very simple way to do this?  A quick guide would be appreciated as I have limited time till spring.
Thanks for your help.
From an email notification about the PGC issues:
We do apologize for the inconvenience and appreciate your patience. In the meantime, if you already have a Polisy - with the exception of Ring and Sonos - all other node servers are already supported in Polisy. Ring and Sonos are being ported as we speak.
Thanks for the info.
So, do I just plug in polisy, start the pg3, and it will recognize my isy and then I download the ring node?  Will all my ring devices show up again?
Just trying to figure it out.
Ring does not yet exist on polisy. Most likely you will have to redo your set up
Got my polisy, plugged in and updated.  Looks like it found my ISY, Portal and has Ring.  It shows 2 nodes - Ring and ISY portal.  How do I sign in to ring - did it automatically migrate?  What else do I need to do at this point.  Hopefully, I don't have to migrate the PLM now.  I have to order a new PLM to connect to the Polisy.
Thanks for any help.
Andrew
Andrew
See @lilyoyo1's post above.  Currently there is not a node server for Ring.  It is probably seeing configuration information from your previous setup.
