Unable to Add Z-Wave devices to IoP.
I Can't seem to add any Z-wave devices to ISY on Polisy ..  ( Yellow Cap Z-Wave Dongle ) (Z-Wave device is 5 feet from dongle)
Fri 02/25/2022 07:19:19 AM : [ZWAVE-TX-NR     ] [0105004AC1F081]                        REQ ZW_ADD_NODE_TO_NETWORK
Fri 02/25/2022 07:19:19 AM : Listening for Z-Wave devices to add to the network
Fri 02/25/2022 07:19:25 AM : [ZWAVE-TX-NR     ] [0105004A85F1C4]                        REQ ZW_ADD_NODE_TO_NETWORK
Fri 02/25/2022 07:19:25 AM : Adding Z-Wave devices stopped
Fri 02/25/2022 07:19:25 AM : [ZWAVE-TX        ] [01030020DC]                            REQ MEMORY_GET_ID
Fri 02/25/2022 07:19:25 AM : [ZWAVE-TX        ] [01030056AA]                            REQ ZW_GET_SUC_NODE_ID
Fri 02/25/2022 07:19:25 AM : [ZWAVE-TX        ] [01030002FE]                            REQ SERIAL_API_GET_INIT_DATA
Fri 02/25/2022 07:19:26 AM : [ZWAVE-TX        ] [01030005F9]                            REQ ZW_GET_CONTROLLER_CAPABILITIES
Fri 02/25/2022 07:19:26 AM : [ZWAVE-TX-NR     ] [0105004A850035]                        REQ ZW_ADD_NODE_TO_NETWORK
Fri 02/25/2022 07:19:39 AM : [        Time] 07:19:41 0(0)
ZW39   Eva Logik
Z-Wave Smart Plug
(Dimmer)
Menu
Z-Wave
Add a Z-Wave Device
BTW.. I have not been able to add any Z-wave devices .
If I try to remove Z-Wave devices I get similar results..  Listening for Z-Wave devices and no response.
3 quick presses and buton begins to blink rapidly.
I added this module..
I tried adding a Z-Wave light switch with no results..
I tried removing the first module  and it removed.
I Added the first module again.
I tried a different modue  with no results.
The plug in modules are added very close to Z-Wave dongle..  I move the one that is added about 15 feet away and it responds to the ISY commands and I can remove it and readd it from it's normal location..
Perhaps there is something still in working stage.. although I have not read about anyone else having these issues.
Is the Zwave box checked, and saved, in the Polisy configuration window?
If so, the then do a reboot on the Polisy by pushing the reset button ONCE in the right front of the polisy using a paper clip,
Edited by Techman
Did all that..
I have not set a ZW device back to factory defaults yet, but I want to wait untill I have this issue fixed before I do that to my installed light switches...
2 hours ago, Jim P said:
Did all that..
I'd return your zwave board and get a new one.
How do you exclude a Zwave device if it has never been added to your IoP ?
Is exclude the same as remove then readd ?
Yes
OK.. I am brain dead !!!
Funny but here is what happened...  I have always only had a single ISY ... Soo...
It never occurred to me to remove my Zwave devices from my 994i before attempting to add them to my IoP ...
This AM I removed one from the 994i and did not have any issues adding it to my IoP..
So I am going forward with removing them all from my 994i and adding them to my IoP.
I am not expecting to see any more issues with this.
Thank you all and sorry to have wasted your time.
