How do you configure the node server?
btreinders
2 hours ago, bpwwer said:
You go to the configuration page and enter your Emporia username and password and save.
@bpwwer So the keys are username and password?  I did that and get this error No module named 'pyemvue'
Edited by btreinders
Looks like one of the dependencies can no longer be installed on a Polisy.  It will take some work to figure out if this can still be supported or not.
Thank you!
  • 2 months later...
Hi  @bpwwer,  I was wondering if you were able to fix the Emporia node server on PG3? Am thinking about getting one, but whatever choice I make I would like it to be supported on IoP.
Tim
No, there's nothing wrong with the node server, one of the python libraries it depends on won't install on a Polisy.   I'll see if something can be done to get the library supported on the Polisy.
I just pushed out version 1.0.3 of this node server.  I think I managed to work around the problem with the library.
I don't see this version in the store.  How do I find it?
The store only updates automatically a couple of times a day. You can manually refresh the listing using the "Refresh Store" button. It's in the Production store.
Seems to be working!  Thank you!
@bpwwer Thank you the current KWH seems to be working for me now but the KWH today is showing what my Vue car charger used. It is also showing as connected now.
It's display the "Main" channel data for both of those.  So that kindof implies that your charger is considered the main channel for daily data?   I don't really know. The only device I have has only the "Main" channel.
Does this node server show data from all 16 C.T.'s if connected? Also, will it recognize the new smart plugs that Emporia sells now which also monitor power consumption?
I am using it with the Vue 2 which has the 16 ct's and today it is showing net production instead of the car charger which I have not used today.
I have 2 panels set up as 2 stand alone. when I set up the node server I get one node that flashes back and forth between the two readings Is there any way to configure it to work can I maybe create two accounts and run two copies of the node server?
I have no idea. Maybe having two accounts would work.
The VUE API isn't a public API and what we're using has been reverse engineered so there could be issues.
The two accounts work. I have the main account with both panels the main and my generator along with my solar panels giving me my total net. and another account with just my generator so I can shut down devices when I am on backup, and the load starts to get High.
Thanks so much for all the work you do in supporting PG3
Kevin
      378.7k
