PG3 IFTTT Webooks Node server 3.0.3
@JimboAutomates, Thanks for building this nodesever!  I am afraid is not clear to me how to use it.   I have the nodeserver all configured in PG3 with the correct api_key etc.  The node server is also showing up in my ISY.  I have created my webhook on IFTTT that triggers an action.  How do add that webhook to my ISY?  Thanks!
Hey nice to see it may be useful for someone else!
On the configuration page where you added your API Key should see these instructions:
https://github.com/UniversalDevicesInc-PG3/udi-poly-IFTTT-Webhooks/blob/master/CONFIGURATION.md
Although there is bug in bug in PG3 where sometimes doesn't show the configuration documentation.
Hopefully those instructions clear it up?
I have found it after I made my post but not sure what values go into each field .
>>Node Address: Enter a short, 8 characters or less node address. Must be unique and should never change
I have use the name "Spotoff" as in spotify off.  Is that correct?  Can be anything as long as it is short, right
>>Node Name: Enter a descriptive node name
 I entered:  This is used to pause Spotify
>>On Event Name: The IFFTT Webhooks event name to trigger for "On". Not required
Not sure what goes here.  There is no "on" action so I left this empty
>>Off Event Name: The IFFTT Webhooks event name to trigger for "Off". Not required
I entered the name of the webhook here. I named it "Spotoff" on IFTTT.  Is that the right value?
Adam
That all looks good, yes the nodeaddress is what you want the node address to be in the ISY, the Node name is what you really se in the ISY so something like "Spotify Pause" would make sense.
So each node it creates can have an "On" trigger and "Off" trigger, this is useful if it's something where on and off make sense.  But you don't have to enter both.  I would put your "Spotoff" in the On event name, then when you turn on the "Spotify Pause" node it will pause spotify.
Getting close!  I now have the Trigger off event in ISY but it does not seem to be firing the webhook.  Seems like I am missing the linkage..  Any ideas?
22 minutes ago, JimboAutomates said:
If it encounters an error the node status will show change. But IFTTT doesn't error out for things like misspelled trigger. Check the Nodeserver log and you should see it send the request to IFTTT?
Getting this error:
2022-03-02 18:28:16,044 Command udi_interface.node ERROR node:runCmd: command DOFF not defined
10 hours ago, JimboAutomates said:
PG3 IFTTT Maker Webooks version 3.0.1 is released, see the Release Notes
Afraid there is still an issue... While I do indeed see 3.0.1 in the node store, my system doesn't want to automatically apply the upgrade.  I am showing the current running version as 3.0.0.  I have:
1. Restarted the node server
2. Ran the upgrade process from PG
3. Dropped to the command line and ran an update/upgrade
4. Rebooted the Polisy
5. just for good measure restarted the IFTTT nodeserver again..
Still shows 3.0.0 and the problem remains.  Any ideas?
11 hours ago, JimboAutomates said:
Ok, sounds like my upload of the new version didn't go through completely. I'll check later.
Any luck?
6 minutes ago, JimboAutomates said:
Need more time in the day not luck, day job kept me slammed today.  Just uploaded again and confirmed it took.
Thanks!  It did indeed take and I am now running the 3.0.1 version.  However, I am still getting the same error.   Could it be a problem on my end?.
2022-03-03 20:47:19,051 Command udi_interface.node ERROR node:runCmd: command DOFF not defined
That's weird. Please download log package and PM it to me
Thanks for your help, @JimboAutomates!   As discussed, I should have been using just the key for my api_key in the configuration vs the entire path+key.
For those considering the IFTTT nodeserver, it works great! I love how you can reference these IFTTT devices right in your scenes and programs.  Very cool
I fear I'm going to need a little hand holding to get this to work.
Goal: Turn a Sensibo connected mini-split on when an Ecobee sensor shows less than desired temperature.
I've added the IFTTT PG3 Node server (today). I'm running it on a Policy.
I added my API Key to the Configuration page.
I created an Applet naming it BRSenOn.
Then I chose 'Receive a web request'.
Then I chose Sensibo, registered Sensibo with IFTTT and filled in the form to indicate On, Heat Mode, Fan Auto.
Then I did this:
What do I do next?
It shows in my admin panel, however I do not see how I can make it work in a program.
Edited by Athlon
Thank you for your quick reply!
I just turned the unit on from my AC after restarting the AC - I had not restarted it (always the simple stuff that stymies me).
And yes, because I have 4 units I will create 4 On and 4 Off events.  I'll attempt that now.
Thank you very much!
Is it possible to trigger both an on event and an off event from one node (Applet)?
The Applet I created only turns the unit on. I've searched their docs and cannot find a way to use one Applet for both states.
