Multiple pushover notifications from ISY
I moved the Notification nodeserver to IoP and it works. However I remember that I was previously able to set type of urgency to messages, such as normal, urgent, emergency (or similar). Regular messages work. Now I don't see anywhere where to set the priority.
Think it depends on the type of message. If you are triggering the message from a program, you can set it there. If from a NR, you have to include it in the string at the top. There's an example on the Configuration page of PG3 of the Nodeserver.
  • Thanks 1
Not true.  it can also be set from the program.  I keep all the /send strings simple with just a node name, i.e. /send?node=po_doortr
I have multiple Pushover nodes:
that each have default Sounds, priority.
I have programs that enforce those:
ServiceNode.doordc - [ID 01C6][Parent 016D]
        'Node Servers / Notification Controller / Service Pushover doordc' Device is not all
     Or 'Node Servers / Notification Controller / Service Pushover doordc' Priority is not Normal
     Or 'Node Servers / Notification Controller / Service Pushover doordc' Format is not HTML
     Or 'Node Servers / Notification Controller / Service Pushover doordc' Sound is not Door Open
        Wait  30 seconds
        Set 'Node Servers / Notification Controller / Service Pushover doordc' Device all
        Set 'Node Servers / Notification Controller / Service Pushover doordc' Priority Normal
        Set 'Node Servers / Notification Controller / Service Pushover doordc' Format HTML
        Set 'Node Servers / Notification Controller / Service Pushover doordc' Sound Door Open
Door Check Tally does do 15 second sound overrides at the end of the cycle.
In some cases I make the wait to change it back 3 seconds... in other cases  30 seconds such as the example below.
In this case the notification that occurs right after the geofence sets away mode will change the default sound for my doorcheck service node (see example below)..  in this way I can tell without looking at the phone if all doors are closed.  The program used does change the sound back... but programs like the one above ensure the node is always set to the correct defaults for the node:
dc16._tally0 - [ID 015E][Parent 015C][Not Enabled]
        $iDoorCheck.tally is 0
        Set 'Node Servers / Notification Controller / Service Pushover doordc' Sound Magic
        Wait  2 seconds
        Resource 'NotificationNS.doordc._TallyZero'
        Wait  10 seconds
        Set '{hide}Node Servers / Notification Controller / Service Pushover doordc' Sound Door Open
        Enable Program 'dc00._trigger.0'
        Run Program 'dc16._tally1' (If)
Edited by MrBill
        Wait  30 seconds
        Wait  2 seconds
        Wait  10 seconds
Something must not be right with my Notification nodeserver. In the Adm. Cons. Main tab my various Pushover nodes show, but each have a "0"  only in message.
When I create a program and select Notification Controller, I have the sub-options Nodeserver Online, REST Status and Notification. With Notification there is again only "0". Nowhere can I select one of the pushover nodes that are listed in the Main tab and same for priority etc.
Right now I use my Pushover email address to send a notification to my phone, but no priority etc,
I may have to re-install the nodeserver.
Edited by asbril
Did you close and reopen the AC?
8 hours ago, JimboAutomates said:
Set log to debug in PG3 UI, restart NS, open AC and if problem still exists download log package and PM that to me.
Thanks @JimboAutomates Mostly resolved by  deleting and re-installing nodeserver. I forgot how to exactly use in  programs. As example I have motion sensors at  the two entrances to my home and also have a smoke detrector and want to send a Pushover messages to my Iphone.
The Iphone connection works when using the Pushover email, so I know that Pushover on my Iphone works.
When I want to send a notification with normal priority when the sensors are activated but high priority when there is smoke, I can see the options when programing, but in what order do I put the various options :
Priority, Set device on  message on motion detected, Set Pushover Device All, anything else ?
The order doesn't matter, only on or off must be last.
  • Thanks 1
Thanks, that helped.
I noticed that I can not get the nodeserver to work both on ISY and on IoP. It is not a big issue as I just use the Pushover email, but I wonder why. Maybe I should try the PG2 version on ISY and keep the PG3 version on IoP.
      378.5k
