Did upgrade to get IoP but now PG3 has discovered my i994 - can I delete it?
Using SSH did all the upgrades so now have PG3 installed and it's seeing my i994 but not my IoP. Before adding IoP I want to "delete current ISY" as I have no PG3 nodeservers, I'm not ready to migrate my PG2 NS to PG3 until PG3 is at least beta and it's polluting my i994 error log with 100's (maybe 1000 a day?) of "System    -170001    [Auth:-10103] 192.168.200.249:22130->80, Num=3" error messages
Problem is I get a message that deleting the ISY will "delete all the existing nodeservers from ISY" and I don't want that to happen. Is it speaking only to PG3 NS's or will it delete my PG2 installed NS's?
I only want PG3 seeing the IoP.
It will only delete the node servers that were installed using PG3.  It won't touch the node servers installed by PG2.
Thanks @bpwwer. Did the delete and no problem in i994.
@Michel Kohanim did the add but IoP not getting added.
here are screenshot showing IoP in launcher, followed by the add screen to show the data, followed by the About screen in IoP from Launcher (i.e. it's there and userid/password I used is correct), followed by PG3 dashboard, which shows no ISYs but does show "ISY version 5.3.4".
a little while later all traces of i994 went away so I guess it just took a while to fully register
Edited by johnnyt
