VUE will not start
Hi @bpwwer, I downloaded VUE tonight but it will not run.  Here is the log info.  I'm running PG3 version 3.0.45.  I have configured the username and password parameters. Suggestions to try?
Thank you.
2022-03-15 20:30:31,058 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2022-03-15 20:30:33,427 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.34 Starting... 2022-03-15 20:30:33,439 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2022-03-15 20:30:33,440 MainThread udi_interface ERROR udi_interface:write: File "./vue.py", line 10, in <module>
2022-03-15 20:30:33,444 MainThread udi_interface ERROR udi_interface:write: from nodes import vue
2022-03-15 20:30:33,445 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:56:10:78_3/nodes/vue.py", line 10, in <module>
2022-03-15 20:30:33,446 MainThread udi_interface ERROR udi_interface:write: import pyemvue
2022-03-15 20:30:33,447 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError
2022-03-15 20:30:33,448 MainThread udi_interface ERROR udi_interface:write: :
2022-03-15 20:30:33,448 MainThread udi_interface ERROR udi_interface:write: No module named 'pyemvue'
Something has changed in the python module dependencies that that it uses but I haven't had time to figure out what.
I think I fixed it so that pyemvue now loads, but something it needs is now failing for me.
Starts for me now and I get the node in the ISY with online status, kilowatt hours and kilowatt hours today but nothing will populate.
On 3/18/2022 at 1:20 PM, btreinders said:
I did update the Polisy just yesterday so maybe.
After more updates yesterday I am seeing True and 0 and 0 as values.  Almost!
I'm getting an error message trying to start this NS
2022-04-08 11:21:32,101 Thread-3   udi_interface      ERROR    udi_interface:write: Exception in thread
2022-04-08 11:21:32,102 Thread-3   udi_interface      ERROR    udi_interface:write: Thread-3
2022-04-08 11:21:32,103 Thread-3   udi_interface      ERROR    udi_interface:write: :
2022-04-08 11:21:32,103 Thread-3   udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-04-08 11:21:32,104 Thread-3   udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
2022-04-08 11:21:32,108 Thread-3   udi_interface      ERROR    udi_interface:write: self.run()
2022-04-08 11:21:32,109 Thread-3   udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.8/threading.py", line 870, in run
2022-04-08 11:21:32,112 Thread-3   udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-04-08 11:21:32,112 Thread-3   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:3a:10_10/nodes/vue.py", line 123, in start
2022-04-08 11:21:32,114 Thread-3   udi_interface      ERROR    udi_interface:write: self.query()
2022-04-08 11:21:32,115 Thread-3   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/00:0d:b9:59:3a:10_10/nodes/vue.py", line 42, in query
2022-04-08 11:21:32,116 Thread-3   udi_interface      ERROR    udi_interface:write: usage = self.vue.get_devices_usage(self.deviceList, None,
2022-04-08 11:21:32,116 Thread-3   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/pyemvue/pyemvue.py", line 81, in get_devices_usage
2022-04-08 11:21:32,118 Thread-3   udi_interface      ERROR    udi_interface:write: response = self._get_request(url)
2022-04-08 11:21:32,118 Thread-3   udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.8/site-packages/pyemvue/pyemvue.py", line 186, in _get_request
2022-04-08 11:21:32,120 Thread-3   udi_interface      ERROR    udi_interface:write: if not self.cognito: raise Exception('Must call "login" before calling any API methods.')
2022-04-08 11:21:32,121 Thread-3   udi_interface      ERROR    udi_interface:write: Exception
2022-04-08 11:21:32,121 Thread-3   udi_interface      ERROR    udi_interface:write: :
2022-04-08 11:21:32,122 Thread-3   udi_interface      ERROR    udi_interface:write: Must call "login" before calling any API methods.
